- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to assign a Revit Material to all of the Fabrication Insulation in my model to display it within Navisworks.
I see that there is a GetInsulationLiningGeometry method for the FabricationPart class which returns a GeometryElement which has a MaterialElement property but it is readonly (get no set). I can create a Material project parameter and set that for the Fabrication Pipework and the Insulation sub category. If I set the parameter to a Revit Material it will come across on both the FabricationPart and the Insulation. I have tried setting the project parameter for the Insulation to be different than the FabricationPart but both the Insulation and the FabricationPart come across as the material that was set for the FabricationPart. It appears that the Insulation Material will only come across with the same Material as the Fabrication Part. Is there any way to have a different Revit Material come across into Navisworks that is not the same as the Material of it's Fabrication Part? I don't want to mess with changing the material in Navisworks.
