- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I am writing an plugin to dimension inserts (family instances) inside an assembly, so far I've managed to create an assembly with all the inserts and create all views and place them on a sheet. Now I want to dimension inserts on each view (only inserts that are on the face relative to the view). Do assembly views have (i.e. ElevationFront, ElevationRight and so on) have a property that relates to a relative face of the main element (in my case it's a column)? So basically I want to check if the reference face of inserts is the same the of reference face of the assembly view and then to dimension them. Or is there another way? thank you for support
