I would like to orient an assembly to the “main” member in the assembly. I am able to get the basis and origin of the “main” member in the assembly and also the assembly itself. I have not been able to identify the most efficient method to achieve this re-orientation.
ElementTransformUtils.RotateElement(document, element.Id, axis, rotation)
RotateElement method appears to be one approach, but seems to be a bit tedious with determining each axis and then rotating about each axis.
Since I have the basis that the assembly needs to be transformed to, is there an easy way to simply set the assembly basis to the new basis?
