Area collector empty (RevitPythonShell)
g_sicre
g_sicre
I am working on a code to grab all built areas for each home in a single-family project, although the dictionary values where areas should be stored it is empty.
Could you tell me what am I doing wrong? I leave the code below.
Thank you.
# Obtención de areas por vivienda
areas = FilteredElementCollector(doc)\
        .OfCategory(BuiltInCategory.OST_Areas)
for i in areas:
    param_portal_id = i.LookupParameter('Portal').Id
    break
for i in areas:
    param_nombre_id = i.LookupParameter('Nombre').Id
    break
param_pro_portal = ParameterValueProvider(param_portal_id)
param_pro_nombre = ParameterValueProvider(param_nombre_id)
param_contains = FilterStringContains()
param_equals = FilterStringEquals()
filter_rule_jardin = FilterStringRule(param_pro_nombre, param_contains, 'Jard'False)
ft_sup_jardin = ElementParameterFilter(filter_rule_jardin)
filter_rule_terraza = FilterStringRule(param_pro_nombre, param_contains, 'Terraza'False)
ft_sup_terraza = ElementParameterFilter(filter_rule_terraza)
areas_viv_dict = {}     # Diccionario con todas las superficies construidas por vivienda con filtros
                        # (key = gate, value = areas list)
for i in range(148😞
    filter_rule = FilterStringRule(param_pro_portal, param_contains, str(i), True)
    ft_sup = ElementParameterFilter(filter_rule)
    areas_viv = areas\
                .WherePasses(ft_sup)\
                .WherePasses(ft_sup_jardin)\
                .WherePasses(ft_sup_terraza)\
                .ToElements()
    areas_viv_dict[i] = areas_viv
jeremytammik
Yes. I see the problem.
areas is a filtered element collector. Every time to add a call to WherePasses to it, a new filter is added. You are adding WherePasses filters to it in a loop, so the elements are being more and more strongly filtered, until (very rapidly) none are left that can pass the filters.
Solutions:
  • Either instantiate a new filtered element collector for each pass through the loop,
  • Or create a Boolean OR clause of the different WherePasses filters and apply the OR once only.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
g_sicre
Hi Jeremy,
thank you for the response. I have been trying both solutions but I am still stuck. However, doing some tests I have realized that something seems not to be working well with the FilterStringRule Class since for both bool value cases the result is always the same. I leave two images with the testing code.
jeremytammik
Yes, indeed, you are perfectly correct.
This issue was recently discussed here in the forum and with the Revit development team:
https://forums.autodesk.com/t5/revit-api-forum/class-filterstringrule-parameter-casesensitive-has-no...
As explained in the other thread, and as you can obviously imagine for yourself, it is easy enough to work around.
Sorry for the confusion, however!
Jeremy Tammik
The Building Coder
