- Mute
- Permalink
- Report
Is there any way to set the Faceting factor when exporting trough the API?
It seems that all exports i make trough API navisworks export are done with a faceting factor of 1 now instead of a higher number.
Things i tried:
- Looking for an option to set it in the API; there seems to be no way to set navisworks trough NWCExportoptions
- Checking the saved faceting factor within the registry; its stored with a value of 10 instead of the default 1; It seems the stored value is ignored when exporting trough the API, and falls back to the default 1 value.
- Edit the registry key just before i call the doc.Export method (but after setting nwxExportOptions); result is the same, its back to default 1 faceting factor.
Are there any options that i can set or try to get it to work?
We automated the export of about 80 nwc exports, but without proper faceting factor we are back to manual exporting where the faceting does work.
