API BreakCurve method creates a new Duct/Pipe without MEPSystem
jlpgy
Message 1 of 1
jlpgy
Hi developers:
There is a method named as BreakCurve in both
MechanicalUtils
 and
PlumbingUtils
It'a an easy approach of breaking a Duct or Pipe.
But, when I was debugging the following simple codes:
                    newElemId = MechanicalUtils.BreakCurve(
                           elem.Document, elem.Id, point);
                    var newDuct = elem.Document.GetElement(newElemId) as Duct;
I found out that the newDuct . MEPSystem property is "null".
This is little bit annoying.
Why does it happen?
In my opinion,if we break an exsiting duct, we break a big connection network into two smaller connection network, which means: at least the new duct after breaking should still share the same SYSTEM TYPE.
Is there any work around? For example, manually set a system type to the new duct or pipe?
And if you have read here, you can also refer to my former post in this forum:
trouble-of-my-own-implementation-of-breakcurve-on-conduit
单身狗;代码狗;健身狗;jolinpiggy@hotmail.com
Replies (0)
