Another Revit 2018 Bug? - IndependentTag.Create with families loaded via the API
- Mute
- Permalink
- Report
Hello All,
I can tell ya, I'm not enjoying the Revit 2018 ride so far.
I've got an issue with the new IndependentTag.Create static method.
See the attached zip with
- 2 commands (with accompanying addin manifest).
- 1 - Loads family symbol, then (tries to) create a tag for the picked floor slab. Fails at IndependentTag.Create .
- 2 - (requires *manual* load of family first) successfully creates a tag for the picked floor slab. Succeeds.
- A floor slab tag family, fresh from the UK Metric family library.
- A test model. Created without a template (metric), with a simple floor slab added.
All API loaded FamilySymbols are activated.
If I'm missing something, let me know. Otherwise, please log and pass along to the development team.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
