Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
An element to .RFA
13 REPLIES 13
Message 1 of 14
1326 Views, 13 Replies
An element to .RFA
Hello, I need to get an RFA file from an element, to upload the file in an API.
Labels (3)
13 REPLIES 13
Message 2 of 14
lukaskohout
What type of element? And what do you mean by uploading the file in API? Can you describe what are you trying to achieve?
It is not as easy as it sounds. At first you need to know what can be done manually in the Revit UI. In most cases you will be able save it only as RVT (Revit project file).
System families and its types cannot be saved as RFA file.
Other loaded families can by default.
Hitting Accepted Answer is a Community Contribution from me as well as from you.
Message 3 of 14
okey, I have an element, such as a wall and I need to upload the wall element to the web, with its api.
Message 4 of 14
lukaskohout
Do you mean Forge, BIM360, webGL or what type of web?
Geometry or information or both? Can you not use IFC?
Just getting wall and uploading it as RFA will not be possible, you can store it only in project.
Message 5 of 14
in reply to: lukaskohout
No, es una web personal.
Message 6 of 14
lukaskohout
Then you need to transform Revit element to some format that the web can show - e.g. webGL.
There is no native way through API.
Message 7 of 14
I can't create an object, so the object becomes an autodesk revit family and output the .rfa file, because if I search for .rfa there are object files like a wall.
Message 8 of 14
lukaskohout
I am sorry I do not understand your workflow, could you post some example?
Message 9 of 14
I have a project, in my plugin I have a list with all the objects of the project, you choose one or several objects and I have to upload that object to the web, which collects a file.
Message 10 of 14
lukaskohout
And the objects are Revit elements? If so, my first reply stands.
You cannot save e.g. wall as RFA.
Message 11 of 14
not a wall, but a window.
Message 12 of 14
lukaskohout
Then you need to get the family of the window and the you can save it to whatever path you want and then upload.
Element e;
FamilyInstance fi = e as FamilyInstance;
Family f = fi.Symbol.Family;
Document famDoc = doc.EditFamily(f);
famDoc.SaveAs("your path");
https://www.revitapidocs.com/2020/c605e437-5f18-81a5-d4ed-e664ba4f941d.htm
Message 13 of 14
Fails in saves as, famDoc.SaveAs (@ "C: \ Users \ victo \ Desktop \ project"); Autodesk.Revit.Exceptions.FileAccessException: 'The model could not be saved: Access Denied. (COleException 0x80030005) '
Message 14 of 14
naveen.kumar.t
Hi @Anonymous ,
You have to provide the file name to save it as a .rfa file.
 famDoc.SaveAs(@"C: \ Users \ victo \ Desktop \ project \ YourFileName.rfa");
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Rail Community
