Allow user to only pick room objects
62BJW
62BJW
I'd like the user to only be able to pick (individual) rooms and no other object types. I looked into Selection.PickObject but how do I get it to select only rooms?
Thanks for the help.
davidd
I think you need to look into the PickObject method with the iSelectionFilter Override
PickObject Method (ObjectType, ISelectionFilter, String):
http://www.revitapidocs.com/2019/e55e4998-ef65-6021-f448-6046be134533.htm
ISelectionFilter Interface:
http://www.revitapidocs.com/2019/d552f44b-221c-0ecd-d001-41a5099b2f9f.htm
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @62BJW
try using the below code
 public class RoomSelectionFilter : ISelectionFilter
            public bool AllowElement(Element element)
                if (element.Category.Id.IntegerValue==(int)BuiltInCategory.OST_Rooms)
                    return true;
                return false;
            public bool AllowReference(Reference refer, XYZ point)
                return false;
RoomSelectionFilter RoomFilter = new RoomSelectionFilter();
                IList<Reference> RoomReferences=uidoc.Selection.PickObjects(ObjectType.Element,RoomFilter) as IList<Reference>;
                foreach(Reference RoomReference in RoomReferences)
                    ElementId roomID = RoomReference.ElementId;
                    Room R = doc.GetElement(roomID) as Room;
                      your code
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
