Advice About learning API forum as a complete beginer
ahmadkhalaf7892
ahmadkhalaf7892
Hello everyone, I was recently informed by my organization that I need to start working with the Revit API, I know how to use Revit quite well and Dynamo also I have a good experience with it.  However, I have no experience at all considering that I don't know anything about C# language or forums,
Here are my questions :
1- what is the best way to learn in this case?
2- Where can I ask and find information?
3- How much usually is time to learn such process?
4- Do I need to learn the whole C# language or just the Revit Api?
I'd appreciate any help with where to start learning and what to do
jeremy_tammik
Welcome to the Revit API!
Normally, I would point you to The Building Coder tips on getting started:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Unfortunately, the Typepad blog host platform is currently having serious problems, so take a look at the GitHub source code of The Building Coder blog instead:
http://jeremytammik.github.io/tbc/a/#2
It answers all you questions in depth, possibly except about time. Still, I'll briefly reiterate:
Start by exploring the Revit UI. You already have. Gain some basic understanding of .NET and C#, of you plan to work in C#. That should be doable in a couple of hours or a couple of days, depending on you. Then, work through the Revit API getting started material. There are walkthroughs, video tutorials, numerous YouTube introductions, hundreds of options. Many have been mentioned and discussed here in the forum in the past.
Please work through the getting started material before asking any questions. If you encounter problems with the getting started material, please search for existing answers. I guarantee that you will not have a problem that has not already been discussed and solved here in the past.
Days, weeks, and years. Depends how far you wish to go. A proficient programmer can understand the system and have a non-trivial macro up and running within hours.
There is no good way to use half a programming language. You have to learn and understand the entire .NET environment. That can be programmed in C# or in other languages as well.
All of this information has been presented hundreds of times in the past, so please search thoroughly for answers before raising any new questions.
Thank you! Good luck and have fun,
Jeremy
ahmadkhalaf7892
Many thanks for the helpful Guidance
Much appreciated
jeremy_tammik
Thank you for your appreciation. Since this is a recurring topic, I edited and reposted our conversation for others as well:
https://thebuildingcoder.typepad.com/blog/2022/11/unit-test-your-revit-add-in.html#4
