I have tried to adjust the analytical floor with the SetOffset and ManuallyAdjust Method but I couldn't succeed.
As I understand, the SetOffset Method only work for curve-based elements (Analytical Beam/Column). Is that true or am I wrong?
With the ManuallyAdjust Method, I couldn't understand exactly what Reference I have to put on the Source and Target in order to adjust the analytical floor (Edge? Line? ...).
I would be grateful for you to help me find out how to do this.
Yuval
Yuval
Do you know how to achieve what you need manually through the end user interface? If so, that knowledge will be very helpful to determine how to achieve the same programmatically. If not, there is nothing to guarantee that it can be achieved programmatically either. Here are some descriptions on how you might proceed to research how to solve a Revit API programming task:
