Adding your own parameter to Revision Cloud/label to Revision Cloud Tag
kozlikjacob
kozlikjacob
Hey! I am new to using Revit API, still going through the docs for a long time. I am wondering if anybody had the same or similar issue. I am trying to add custom parameter to Revision Cloud or custom label to Revision Cloud Tag. I am wondering whether it is even possible?
Yien_Chao
i believe we can't yet and i think this was a request from long time.
kozlikjacob
Thanks for the reply! So even APi is not going to help. Thanks a lot, I will wait then 😄
Yien_Chao
meanwhile, i use the "comments" parameter of the cloud revision to do schedule filtering.
jeremy_tammik
I would expect that a shared parameter can be added to a revision cloud. They can be added to almost any element. I tried lots of them way back then:
https://thebuildingcoder.typepad.com/blog/2016/12/material-shared-parameters-and-adn-xtra-labs.html
Yien_Chao
@jeremy_tammik  can't find any info in your link about Revision cloud parameter. i've tried again with shared Parameter and Revision cloud is not available in the category menu. maybe you have a secret trick?
