Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Adding Project Template to 'New Project' via API
mhillis
mhillis
I noticed that the UI method for adding a project template to the 'New Project' dialog on the Start Window is by going to Options->File Locations and clicking the little plus symbol.  Is there any way to achieve this same effect using the API?  I would like to add templates to the dropdown.
jeremytammik
Dear Michael,
Thank you for your query.
I asked the development team for you.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
pgerz
You can do it by editing the C:\Users\%username%\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2019\Revit.ini file with standard .NET functions.
Section [DirectoriesENU] --> DefaultTemplate
Example:
string oriDatei = @"" + Environment.GetEnvironmentVariable("appdata") + @"\Autodesk\Revit\Autodesk Revit 2019\Revit.ini";
            string tmpDatei = @"c:\temp\11.ini";
            if (System.IO.File.Exists(oriDatei))
                using (StreamReader sr = new StreamReader(oriDatei, Encoding.Unicode))
                    StreamWriter sw = new StreamWriter(tmpDatei, false, Encoding.Unicode);
                    string inputLine = "";
                    while ((inputLine = sr.ReadLine()) != null)
                        if (inputLine.StartsWith("DefaultTemplate="))
                            if (inputLine.Contains("Example_SCHEMA.rte"))
                               // do nothing
                            else
                                inputLine = inputLine + @", Example_SCHEMA=C:\temp\Example_SCHEMA.rte";
                        sw.WriteLine(inputLine);
                    sw.Close();
                System.IO.File.Replace(tmpDatei, oriDatei, null);
Cheers
Peter
jeremytammik
Dear Peter,
Thank you for the cool and simple solution.
I added it to the blog to preserve it for posterity:
https://thebuildingcoder.typepad.com/blog/2019/02/accessing-useful-settings-in-the-ini-file.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
cig_ad
Also, just discovered, - Autodesk.Revit.ApplicationServices.Application.CurrentUsersDataFolderPath returns the path where revit.ini is located.
