Adding Leaders to Tags
bndlyosi
bndlyosi
I'm trying to add a Leader to a tag via revit api
and I am not succeeding
The question is whether there is such a possibility
Or alternatively change the tag to a different tag as it is possible to add a Leader
Thank you Yossi
ricaun
Yes is possible,
Inside the IndependentTag Class you have the HasLeader.
Set to true should enable the Leader.
IndependentTag independentTag = ...
independentTag.HasLeader = true;
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
bndlyosi
thank you for the answer
But HasLeader defines whether there will be a tag or not
I'm looking to add a tag
vadim.parnitski
Good time of day. Add and remove leaders using the addLeader() and removeLeader() methods.
public void AddAndRemoveLeaders(AnnotationSymbol symbol)
            // check if there are any leaders currently attached, and remove them
            IList<Leader> leaders = symbol.GetLeaders();
            if (leaders != null)
                for (int i = leaders.Count; i > 0; i--)
                    symbol.removeLeader();
            // add one new leader instead
            symbol.addLeader();
Vadym Parnytskyi | Вадим Парницький
BIM Expert & Autodesk Instructor & CEO BIMHELP
FacebookFacebook | LinkedInLinkedIn | YouTubeYouTube
