& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I want to make custom analytic construction options available, by adding an additional .xml, and not by editing the existing constructions.xml. Is there someway i can write a manifest that makes my own code interpreted the right way, or is this not possible?
I asked the development team for you. However, they may not even know. I hope someone does. 🙂
Thanks a lot Jeremy!
I appreciate it your help 🙂
The devteam say:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
Tag it as an API wish:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent/label-name/api
Ensure it gets as many votes as possible to underline its importance to you and the rest of the developer community.
The Revit Idea Station is currently one of the main driving input forces for Revit API enhancements.
The Revit development team look there. Your comment here in the discussion forum might be overlooked.
Thank you!
Hi Jeremy,
thank you so much for your help!
I really appreciate it. I will post in the Revit ideas forum.
I don't use Export to gbXML, Energy Analysis, Heating and Cooling Loads. The reason i was trying to solve this, was so that the company I work for, could make their glazing units available to users in Revit, instead of having the user manually typing in the technical values of a window.
Cheers! 😊
Thank you for the clarification. I passed it on to the devteam.
They reply:
Thanks for the info. So as I understand, Fredrik want to add his own Analytical Constructions to be available for selection in Revit Window and Door Types. I will forward the request.We did, however, opened up Analytical Properties to be user defined for Window and Door Types in Revit 2020. Maybe that can help? Fredrik could provide a set of predefined types in a Revit template?
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
