Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Adding a value to a shared parameter in a project.
6 REPLIES 6
3120 Views, 6 Replies
I have been 2/3 weeks working with the Revit API and I need some help.
I am creating an external command that creates a shared parameter file and binds it to the OST_Sheets category and I want to add a string value to one of the parameters i have just created.
I am struggling with this as most of the solutions are regarding rfa files.
I created a filteredElementCollector collecting the sheets in my file and I do not know where to go from there... can somebody please help me with solution or a link that might me of use? I am a c# coder.
Much appreciated, Thank you.
6 REPLIES 6
augusto.goncalves
To set a parameter value, simply call
viewSheet.get_Parameter("NAME_HERE").Set(newValue)
And check our tutorial at http://www.autodesk.com/myfirstrevitplugin and blog http://thebuildingcoder.typepad.com
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
in reply to: augusto.goncalves
I tried the get_Parameter method, theres a problem with using it because it is asking for a BuiltInParameter and i am uising one i created in a shared parameters .txt file :(.
augusto.goncalves
The get_Parameter has 4 overloads, one will receive a string, where you can pass the shared parameter name
Augusto Goncalves
Revit 2015 added LookupParameter method to elements.
Use it like so:
viewSheet.LookupParameter("MyParam").Set("TestValue");
Rail Community
