Addin be an element selector, have elements selected when addin terminates
I assume an addin can terminate with elements selected because I've seen addins do that. How is this accomplished? I have not seen any examples for this. User selection and automatic selection tasks within the running addin are easily accomplished. What is needed is to have the addin perform the selection task and then exit leaving the selected items still selected so that builtin commands that can operate on a preselection be invoked by the user.
Mustafa.Salaheldin
This example will select all walls in the model and leave it selected. Adjust it to the type you want by replacing the Wall class with the desired one.
Please if this solution satisfies your need don't forget to mark the reply as an answer:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace BIMOasis
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                //SelectionFilterElement sf = new SelectionFilterElement();
                FilteredElementCollector collector = new FilteredElementCollector(cmdData.Application.ActiveUIDocument.Document).OfClass(typeof(Wall));
                List<Element> elements = collector.Cast<Element>().ToList();
                List<ElementId> Ids = new List<ElementId>();
                foreach (Element e in elements)
                    elemSet.Insert(e);
                    Ids.Add(e.Id);
                cmdData.Application.ActiveUIDocument.Selection.SetElementIds(Ids);
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
        #endregion
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
I had tried Selection.SetElementIds(Ids) without any luck before posting the question. I was using Ids as an
ICollection<ElementId>
within a transaction.   I'll give it another try to see if I can make it work.  Thanks again.
Mustafa.Salaheldin
Just try my code and tell me it didn't work. My solution is tested and verified. Smiley Wink
¯\_(ツ)_/¯
Mustafa Salaheldin
Thank you Mustafa.  I think what is needed is to invoke the Selection.SetElementIds at the top level IExternalCommand level. I was able to get this working only by passing the Id list back up to the top as shown in this code. I guess there is a basic concept I am missing that I might know in the future.
    class CmdAimManyLights : IExternalCommand {
        public Result Execute(ExternalCommandData commandData,
                             ref string message,
                             ElementSet elements) {
            UIApplication uiapp = commandData.Application;
            UIDocument _uidoc = uiapp.ActiveUIDocument;
            Autodesk.Revit.ApplicationServices.Application _app = uiapp.Application;
            Autodesk.Revit.DB.Document _doc = _uidoc.Document;
            PlunkOClass plunkThis = new PlunkOClass(commandData.Application);
            BuiltInCategory _bicItemBeingRot = BuiltInCategory.OST_LightingFixtures;
            List<ElementId> _selIds;
            plunkThis.TwoPickAimRotateMany(_bicItemBeingRot, out _selIds);
            _uidoc.Selection.SetElementIds(_selIds);
Mustafa.Salaheldin
OK I'm happy that could help and please don't forget to mark your reply as an answer too.
¯\_(ツ)_/¯
Mustafa Salaheldin
