This example will select all walls in the model and leave it selected. Adjust it to the type you want by replacing the Wall class with the desired one.
Please if this solution satisfies your need don't forget to mark the reply as an answer:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace BIMOasis
[Transaction(TransactionMode.Manual)]
[Regeneration(RegenerationOption.Manual)]
public class ExtCmd : IExternalCommand
#region Cached Variables
private static ExternalCommandData _cachedCmdData;
public static UIApplication CachedUiApp
get
return _cachedCmdData.Application;
public static RvtApplication CachedApp
get
return CachedUiApp.Application;
public static RvtDocument CachedDoc
get
return CachedUiApp.ActiveUIDocument.Document;
#endregion
#region IExternalCommand Members
public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
_cachedCmdData = cmdData;
try
//SelectionFilterElement sf = new SelectionFilterElement();
FilteredElementCollector collector = new FilteredElementCollector(cmdData.Application.ActiveUIDocument.Document).OfClass(typeof(Wall));
List<Element> elements = collector.Cast<Element>().ToList();
List<ElementId> Ids = new List<ElementId>();
foreach (Element e in elements)
elemSet.Insert(e);
Ids.Add(e.Id);
cmdData.Application.ActiveUIDocument.Selection.SetElementIds(Ids);
return Result.Succeeded;
catch (Exception ex)
msg = ex.ToString();
return Result.Failed;
#endregion
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook |
Twitter |
LinkedIn
