Add shared parameters
Message 1 of 8
I am working on REVIT MEP2014 and I would like to add a shared parameter on ducts and pipes.
Is it possible to make an addition between the native parameter "elevation", "height" of ducts and pipes and a new shared parameter?
Replies (7)
Message 2 of 8
AroChris
Hi Maxime,
Yes, it's possible to add shared parameters on ducts, pipe , with project parameters.
Unfortunately impossible to make calculations between parameters without using the programming.
That's what I had to do to automatically process the dimensions NGF for ducts, pipes and reservations on Revit MEP.
I am French and Revit MEP specialist for AutoDESK
For further information you can reach me directly by email (arochris@arodev.fr)
Bests Regards.
Message 3 of 8
augusto.goncalves
As mentioned, a shared parameter will have a value that will not change automaticaly, but if you need this calculated value, you can also consider a schedule with a calculated value. This will not require any APIs.
Sure, if you need the value appearing at the property palette, then you need a shared parameter and a plugin/API to maintain it updated.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 4 of 8
Message 5 of 8
It's seems to be intersting.
But how can I do concreetly.
Best regards
Message 6 of 8
augusto.goncalves
At the create schedule window, when adding a parameter, just select the button 'Add Calculated Value', where you can perform some simple math with existing parameters...
Augusto Goncalves
Message 7 of 8
AroChris
The problem is that the calculated value in the schedule can not be exploited in a label to display the results on plan view
Regards
Message 8 of 8
AroChris
Regards
