Add Label in Ribbon Panel
HI everyone
I developing my addin using C# 2012 and api Revit 2016. I Need add a Label control to a Ribbon Panel. Similar to the menu "Collaborate" option"Active Workset" .
this can be done?, some example code c#?
i try disabled pushbutton but it is not what I want.
tranks
jeremytammik
Sorry, the disabled push button is the best I have to offer at the moment:
http://thebuildingcoder.typepad.com/blog/2010/09/simulating-a-ribbon-textbox-label.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thanks Jeremy
but it is not what i want
jeremytammik
Revitalizer
what about a simple PushButton without any Image and bound to a dummy command, doing nothing ?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Revitalizer
forget my previous post, didn't read that you already used a PushButton.
You may consider using AdWindows.dll, there is a class called "RibbonLabel" in it.
No code so far, just an idea or hint.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
