Add Custom Columns to Key Schedule
I need to show custom data in a key schedule. I was able to add additional rows to the schedule, and to write some text into each cell, but I can't find a way to add additional columns to the schedule. I added shared parameters to the category I used (Room), but from what I understand, it's impossible to show shared parameters in their own column.
The screenshot shows my schedule, and I want to add additional columns to the right.
Can anybody help me?
Thanks a lot!
tuuletin
Hello!
Sounds like you are doing everything right. As it doesn't work, I guess, parameters should not be shared, but only local (and only a n instance parameter).
When you create a key schedule, you can add a parameter.
Also, when you click "Add Parameters...", you can create only instance parameter.
So, check you parameters' properties. Cat Tongue
tuuletin
Oh, sorry, I didn't notice in my RSS-feed, that it was the revit api forum... I guess, the author wants to make this via API...
So sorry, excuse me, please Cat Indifferent
