Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
acedGetPoint in Revit
1 REPLY 1
sizy458
135 Views, 1 Reply
Hello ,
How do i do programmaticaly in evit for pick two points with jig line ?
Selection sel = uiDoc.Selection;
var p1 = sel.PickPoint(ObjectSnapTypes.Nearest);
var p2 = sel.PickPoint(ObjectSnapTypes.Nearest);
p2 = p2;
I don't see method with origine point , How trace jig line ?
Thank.
1 REPLY 1
jeremy_tammik
in reply to: sizy458
The Revit API does not provide the functionality of AutoCAD ObjectARX AcEd jigs.
You can try to simulate it with workarounds:
However, I would recommend just sticking to the standard UI functionality officially supported by the Revit API whenever possible, and re-think your UI input methods until they fit into the Revit API UI standards.
Jeremy Tammik, Developer Advocacy and Support, The Building Coder, Autodesk Developer Network, ADN Open
Autodesk Customer Advisory Groups
Rail Community
