Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
accessing Pushbutton of a command from inside the command
3 REPLIES 3
tephraimCHQM3
194 Views, 3 Replies
tephraimCHQM3
Hello everyone,
I want to disable the button of an external command when the user clicks it.
After the command finished running, I want to enable back the push button.
The reason behind this is that I don't want to have several instances of the command running, only one at a time.
One way I though to to make this happen is by changing the PushButton.Enabled property of the relevant push button. To do that I need access to the commands corresponding push button.
Any Idea of how can I do that?
I will note that my externalApplication and externalCommand  reside in 2 different projects, so they can't easily access each other.
Hello everyone,
3 REPLIES 3
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @tephraimCHQM3 ,
Are you looking for this one?
Autodesk.Windows.RibbonControl ribbon = Autodesk.Windows.ComponentManager.Ribbon;
                foreach (Autodesk.Windows.RibbonTab tab in ribbon.Tabs)
                    if (tab.Title.Contains("Add-Ins"))
                        foreach (Autodesk.Windows.RibbonPanel panel in tab.Panels)
                            if (panel.Source.Id == "EXTERNAL_TOOLS_PANEL")
                                panel.IsEnabled = false;
                                //Do your Work Here
                                //After completing your work
                                panel.IsEnabled = true;
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Hi @tephraimCHQM3 ,
                                //Do your Work Here
Naveen Kumar T
ricaun
in reply to: tephraimCHQM3
ricaun
Hello!
Probably the easiest way is using the IExternalCommandAvailability with a static variable to enable/disable your button.
The Availability of the button could be applied when um create the PushButtonData on the AvailabilityClassName property, like the ClassName property.
Here is a simple implementation of the IExternalCommandAvailability with the static Enabled
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace RevitAddin
    public class AvailableOnProjectButtonEnabled : IExternalCommandAvailability
        public static bool Enabled { get; set; } = true;
        public bool IsCommandAvailable(UIApplication uiapp, CategorySet categorySet)
            if (uiapp.ActiveUIDocument == null) return false;
            if (uiapp.ActiveUIDocument.Document == null) return false;
            if (uiapp.ActiveUIDocument.Document.IsFamilyDocument) return false;
            return Enabled;
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Hello!
            return Enabled;
See yaa!
tephraimCHQM3
Thanks @ricaun and @naveen.kumar.t  for the answers.
Even though @ricaun answer is indeed a possible solution, the one provided by @naveen.kumar.t is more fitted to my needs.
Here is my final implementation:
        public static void SetToolEnabledValue(string ribbonItemText, bool value)
            RibbonTab ribbonTab = ComponentManager.Ribbon.Tabs
                .FirstOrDefault(tab => tab.AutomationName == "TAB_NAME");
            if (ribbonTab != default(RibbonTab))
                foreach (Autodesk.Windows.RibbonPanel panel in ribbonTab.Panels)
                    foreach (Autodesk.Windows.RibbonItem ribbonItem in panel.Source.Items)
                        if (ribbonItem.AutomationName == ribbonItemText)
                            ribbonItem.IsEnabled = value;
                            return;
                            return;
