About Revit & C# Software Development Support.
tufan.sezgin
Message 1 of 1
tufan.sezgin
Our company is one of the few manufacturers opened to the world in the water slides sector and is in the first rankings. For detailed information, please review;
https://www.polinglobal.com
For our use of Autodesk Revit, a special plug-in was developed for our company that can work in Revit in 2019, it was stated that it is based on C#, this plug-in should be revised to eliminate the incompatibilities caused by the version change with the obligation to update Revit every year. In addition, since the plugin is currently in the testing phase, its performance could not be evaluated. The database library required by Revit and the plugin has not yet been fully created. In addition, additional features will need to be added to this plugin as tests are carried out.
Obviously, the software developer who needs support for us should be able to adapt to Revit, that is, know Revit and use the C# software language. Can you support this issue or contact someone who can help with this issue?
E-Mail : tufan.sezgin@futuraform.com.tr
Thanks.
Replies (0)
