About 3D views properties
nitinjambhale
nitinjambhale
Hello All,
Is there any way we can apply ViewDirection same as that of when we click on "Home" button for active 3D view programmatically with Revit API?
Thank You,
- Nitin J.
matthew_taylor
Hi @nitinjambhale,
It appears that GetHomeCamera will give you what you need:
http://www.revitapidocs.com/2017.1/dadadb67-e2f8-f2f4-0346-742cea12452f.htm
Then you can use its properties with this to set it:
 view3D.SetOrientation(New DB.ViewOrientation3D( ....
(Intellisense should make it all pretty obvious.)
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
