A macro that simply prints pdf
osayed643PD
osayed643PD
Hi all, I haven't found anything too similar, the things I found were way too much.
I would just like a few lines of c# code that print a selected view set based on set print settings.
I have already written it in python but with some errors.
but please keep it as simple as possible.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @osayed643PD ,
Please take a look at this below link
https://www.revitapidocs.com/2023/29599e18-cad8-813e-dc6e-04350fe37944.htm
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
naveen.kumar.t
Autodesk Support
Autodesk Support
If you want to export views to PDF, you can use Export Method (String, IList(ElementId), PDFExportOptions).
Also please take a look at this link PDFExportOptions Class
Naveen Kumar T
osayed643PD
thanks, but how do I specify the viewset I want to use?? sorry ive been using only python
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @osayed643PD ,
Please take a look at these below links
Link 1
Link 2
Naveen Kumar T
