3D view facing North
Hi
After a while I have started on the automatic 3D views creation again, still with no luck.
The North direction is still wrong.
When I use the eye, Up, Forward settings as below, North is turning Right insted of up
XYZ eye = new XYZ((SecBMin.X + SecBMax.X) / 2, (SecBMin.Y + SecBMax.Y) / 2, 1); // in the middle of the section box
XYZ up = XYZ.BasisY;
XYZ forward = XYZ.BasisZ;
If I swap the Up and Forward Z/Y:
XYZ up = XYZ.BasisZ;
XYZ forward = XYZ.BasisY;
Now I got the direction right, but the eye target is not placed in the midtel af the outer walls don't seem prarallel.
What do I do wrong ?
Isn't it possible to create a 3D perspective facing North ?
If not, is it possible to rotate the view after creation ?
Best Regards
Anders
jeremytammik
Dear Anders,
Thank you for your query.
I cannot say off-hand what might be wrong, but I am certain that you can create the view oriented in the manner you need.
Have you taken a look at The Building Coder topic group on Creating and Setting Up a 3D View?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.37
I hope some of the discussions and examples there help resolve the issue.
Please let us know how you end up solving this and what the problem was.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hi Jeremy
I have tried, and the view is perfect with crop, eye Target etc, if it is in the right direction !!
The 3D view have settings like this
Up Direction         (-1, 0, 0)
Right Direction     (0, 1, 0)
View Direction     (0, 0, 1)
When I manualy correct the view with Top facing North
The settings look like this
Up Direction         (-1.57009245868378E-16, 1, -2.20937357914267E-16)
Right Direction     (1, -1.57009245868378E-16, -1.53018136212116E-31)
View Direction     (1.18328928261845E-31, 2.20937357914267E-16, 1)
Can you get something out of those settings ?
For you information, We started the subject at:
http://forums.autodesk.com/t5/revit-api/setting-3dview-to-topview-and-north-upwards/m-p/5612946#M979...
Best Regards Anders
jeremytammik
Dear Anders,
Thank you for your update.
You understand the exponential notation xxxE-16, where x are digits, I assume?
E-16 and E-31 means 'multiplied by 10^-16' and 10^-31, respectively.
In other words, very small numbers indeed.
In other words, these numbers can be equated with zero.
In other words, the manually generated settings are
  Up Direction     (0, 1, 0) = XYZ.BasisY
  Right Direction  (1, 0, 0) = XYZ.BasisX
  View Direction   (0, 0, 1) = XYZ.BasisZ
Does that help?
Did you look at the background documentation that I pointed to responding to your other related query?
The description of the views in the developer guide:
Welcome to Revit 2016 Learning
http://help.autodesk.com/view/RVT/2016/ENU
Revit API Developers Guide
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-F0A122E0-E556-4D0D-9D0F-7E72A9315A42
Basic Interaction with Revit Elements
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-54D8EFF1-5274-43D8-BD0C-68209F36BBD2
Views
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-A7CE4D5C-8839-4CD8-817F-BE8B17F91D97
View3D
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-A7FA8DBC-830E-482D-9B66-147399524442
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Hi Jeremy
Finally I got I right
I am not sure it is "by the book" but it is working Smiley Happy
I  put in an negativ value in the XYZ forward, then all the 3D view are in the right view, facing North.
XYZ eye = new XYZ((SecBMin.X + SecBMax.X) / 2, (SecBMin.Y + SecBMax.Y) / 2, 1); // Center of the sectionBox
XYZ forward = -XYZ.BasisZ;
view.SetOrientation(new ViewOrientation3D(eye, up, forward));
Then I locked the view
view.SaveOrientationAndLock();
and at last set the eye and target elevation to the right value
Parameter EYE_ELE = view.get_Parameter(BuiltInParameter.VIEWER_EYE_ELEVATION);
EYE_ELE.Set(....
Parameter Tar_ele = view.get_Parameter(BuiltInParameter.VIEWER_TARGET_ELEVATION);
Tar_ele.Set(.....
Have a nice weekend
Anders
