3D Sweep Path
3D Sweep Path
Dale.Bartlett
3D Sweep Path
Dale.Bartlett
Given that it is possible to generate a 3D Sweep by selecting edges to generate a path:
http://forums.autodesk.com/t5/revit-architecture/3d-path-sweep/td-p/5623886
Then it must be possible to generate a 3D path from a series of points. Unfortunately I can't see how. Any suggestions? Regards Dale
______________
Yes, I'm Satoshi.
jeremytammik
Dear Dale,
Thank you for your query.
Sure this is possible.
Here are a couple of discussions on The Building Coder on sweeps and sweep creation:
There should be something in there that helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
