3D curve rebar
3D curve rebar
Message 1 of 8
3D curve rebar
It seems the methods provided by the Revit API can only create rebar in a plane. Is there a way to create rebar along a space (3D) curve?
Replies (7)
Message 2 of 8
jeremy_tammik
Pleas always search the available resources before asking a question here.
In this case, please search the Revit SDK samples for `RebarShape`.
One of the samples provides is MultiplanarRebar.
This sample is to demo multiplanar rebar creation in API. A user scenario of multiplanar rebar is corbel reinforcement. This sample reinforces sloped corbels.
Cheers,
Jeremy
Message 3 of 8
Hi Jeremy, thank you very much for your reply. What I want is a method to create a rebar with an arbitrary 3D shape, which is sometimes required in the longitudinal reinforcement of double-curved bridge. I created a HermiteSpline from a series of XYZ points and use the curve as the center line of rebar.  The MultiplanarRebar may not be the solution. However, I found the free form rebar may be able to do that. I will try that.
Message 4 of 8
jeremytammik
Maybe this free form rebar distribution is exactly what you are after:
https://youtu.be/13RWV0Augfc
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 5 of 8
Hi Jeremy, I can get what I want using the free form rebar. Thank you for your help.
Message 6 of 8
jeremytammik
Congratulations!
Thank you for your appreciation.
Please share a snippet or two of sample code to show others how you ended up solving this.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 8
The code is really simple, as follows:
List<XYZ> pts = …  // define my XYZ points
Curve curve3D = HermiteSpline.Create(pts, false);
CurveLoop curveLoop = new CurveLoop();
curveLoop.Append(curve3D);
List<CurveLoop> curveLoops = new List<CurveLoop>();
curveLoops.Add(curveLoop);
Rebar rebar = Rebar.CreateFreeForm(document, barType, host, curveLoops, out error);
This method is simple, and no constrain can be applied. But it seems good enough for my current task.
Message 8 of 8
2327398194
Observer
Observer
Hello, how did you develop the plug-in for the free form reinforcement shown in the video?
