2016 API Bug at LineLoad curve indexing?
StruSoft_Iwona
StruSoft_Iwona
I have a plate with 6 edges. I want to create a LineLoad on the first line (with index 0) but it throws exception. I tried it with all the other lines and it worked. First I thought the indexing maybe starts with 1 but i can access only to 5 line from the 6.
It happened with revit api 2016. I want to prepare my program to revit api 2017 and now I just slaying the obsolete method calls.
Is this a known bug? Or am I misunderstand something? Is there a solution for this?
Mustafa.Salaheldin
Check first the type of ReferenceM when the exception is thrown
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
JimJia
Dear Iwona Budny,
Per investigation, I also confirmed Revit 2016 has issue for this API(sorry if it's bad news for you), however it works well against Revit 2017, I think you can upgrade your program to Revit 2017 safely; I didn't see obsolete warning for this API.
Besides, you may notice API documentation below for this curve index parameter, FYI:
// The index of a curve in analytical surface element starting from 0. Use
// Autodesk::Revit::DB::Structure::AnalyticalModelSurface::GetLoops(Autodesk::Revit::DB::Structure::AnalyticalLoopType::All)
// method to obtain appropriate curve index. Curve index has a unique value
// in analytical surface element even if it contains more than one loop. The
// index should be obtain by iteration through all curves in all loops.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
