Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
2015 to 2016 grid line reference problem
4 REPLIES 4
desdinova
626 Views, 4 Replies
ReferenceArray thirdDimension = new ReferenceArray();
            IList<Reference> myRefs = uidoc.Selection.PickObjects(ObjectType.Element, "Pick");
            foreach(Reference r in myRefs)
                Element element = doc.GetElement(r);
                Grid grid = element as Grid;
                Line gridLine = grid.Curve as Line;
                XYZ direction = gridLine.Direction;
                thirdDimension.Append(gridLine.Reference);
            XYZ firstPoint = uidoc.Selection.PickPoint("Select first point");
            Line firstLine = Line.CreateBound(new XYZ(firstPoint.X + 200, firstPoint.Y, firstPoint.Z), new XYZ(firstPoint.X - 200, firstPoint.Y, firstPoint.Z));
            using (Transaction t = new Transaction(doc, "Add Dimension"))
                t.Start();
                Dimension third = doc.Create.NewDimension(doc.ActiveView, firstLine, thirdDimension);
                t.Commit();
Helo everyone
The code above works revit 2015 but does not work 2016
There is no error when compling
How can i solve this
Thanks in advance...
4 REPLIES 4
boostyourbim
in reply to: desdinova
In 2016 get the grid reference like this:
Reference gridRef = null;
Options opt = new Options();
opt.ComputeReferences = true;
opt.IncludeNonVisibleObjects = true;
opt.View = doc.ActiveView;
foreach (GeometryObject obj in grid.get_Geometry(opt))
if (obj is Line)
Line line = obj as Line;
gridRef = line.Reference;
desdinova
in reply to: boostyourbim
Thank you it worked.
hi, i got the same problem with the dimensioning between grids but your solution doesn't work in my case. the reference of the line is always null.
Removing the view from the geometry options might make it work for you.
Autodesk Customer Advisory Groups
Rail Community
