Post to forum: Board selection does not work
When creating a post in the inventor forum you have the option to pick a board to post it on. If you choose Inventor iLogic and VB.net Forum the board selected is ignored and the post remains in the board you initially started the post. This leaves posts popping in the wrong boards with no option to change. The only workaround is to create the post again in the after switching to the correct board. For folks that work across multiple boards I can see this being a major issue.
2 Comments
pendean
Community Legend
Umm, that's how all of these forum work and have worked. Not sure it's ever been different.
A.Acheson
Thanks for checking. If that is the way it always was what would the option for board selection be used for? If it is redundant it should be removed in my opinion.
