Steps to reproduce
REPEATING an earlier request about a RECURRING PROBLEM:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/trim-any-line-in-a-layer-to-5mm-on-b...
In line 15 of the code window, there's an 8 followed by a SPACE and then a right parenthesis ). That space between them should not be necessary, but without it, the 😎 disappears. Outside a code window they would turn into an emoticon, but inside one they just go away, which DESTROYS THE CODE COMPLETELY. I only happened to notice, and went back in to "fix" it by adding the space between (fortunately it happens to still work that way), but not everyone will even know to look, much less how to fix it.
Expected results
That an 8 followed by a ), at least within a code window, should remain an 8 followed by a ).
Actual results
Inside a code window, the two characters are eliminated; outside in the Message body, they are converted to an emoticon -- those really have no place in a technical forum like this anyway, so I would prefer that emoticon-trigger capability be removed from the site entirely.
URL where issue occurs
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Browser
Microsoft Edge
OS
Windows
