Dynamic Blocks forum doesn't show solved cases
Steps to reproduce
Most other boards show how many cases users have solved. However, the Dynamic Blocks forums, https://forums.autodesk.com/t5/dynamic-blocks-forum/bd-p/154, doesn't. It only shows the names of the solution leaders.
Expected results
Display the number of solutions for each solution provider.
Actual results
Only the name is being shown.
URL where issue occurs
Browser
Firefox
OS
Windows
6 Comments
pendean
Community Legend
@Ed__Jobe That's prevalent is many Forums, not just one. In fact, where you see the numbers seem to be the minority.
Explore when you get a chance.
Ed__Jobe
Thanks @pendean , yes I see that. I was just hoping they would fix it because it's a nice feature. @handjohnathan
kevinle2
Status changed to: Under Consideration
Hi @Ed__Jobe ,
I will create an improvement ticket for this. However if we do this for the Dynamic Blocks forums, it would have to be applied to all of the forums. We are currently doing a redesign of the forums so we will put this into consideration.
Ed__Jobe
Hi @kevinle2 Yes, it should be done for all forums. The AutoCAD, Lisp, NET and VBA forums have it. This was just one example of a forum without it. Here is a screenshot of the acad forum.
Ed__Jobe
Now, all the forums that once had them are missing! You're going backwards!
pendean
Community Legend
@Ed__Jobe I suspect a 'reset' is in the works and that might involve removing "old" before "new" can be implemented.
Baby-steps...
