Remake in a never ending "install new version" loop: Solution
barmanr
Alumni Alumni
Message 1 of 11
barmanr
Hi All,
There have been reports that ReMake ends up in a loop even if the latest update is installed. In order to resolve this issue please follow the steps below:
  1. Please try removing all the ReMake folders from this location: C:\Autodesk. This is where the browser usually downloads the non extracted Remake files before install.
  2. Once that is done, Please uninstall Remake and do a clean download and install directly from this link: http://up.autodesk.com/2018/MMNTO/ReMake_172531_Win64_dlm.sfx.exe
This issue arises usually due to the fact that either the system clock is showing a wrong date or some conflict with the version files in your directory.
Thanking You.
Warmest Regards,
Rishov Barman
SQA Engineer, ReMake
Rishov Barman
Reality Capture
Replies (10)
Message 2 of 11
ena.ernest
This does work but is this the free version?  I did restart after uninstalling the previous version.  I have the pro subscription but I am not receiving the 250 photos.
Message 3 of 11
devangshah
Hello all,
We have a new version of ReMake available at:
http://up.autodesk.com/2017/MEM/ReMake_172521_Win64_dlm.sfx.exe
Kindly use this new link.
You may also visit the following link to ensure downloading the latest version.
https://remake.autodesk.com/try-remake
Devang
Message 4 of 11
devangshah
Hello all,
A new version of ReMake is now available at:
Devang
Message 5 of 11
Issue still persists, uninstalled and reinstalled several times now, cleared the C:\Autodesk\ folder for ReMake folders and restarted computer. Any suggestions? Thanks.
Message 6 of 11
devangshah
What ReMake version are you using ?
The latest version that needs to be installed is v 17.25.3.1 .
The latest installer can be downloaded from the ReMake website at:
Devang
Message 7 of 11
The link mentioned https://remake.autodesk.com/try-remake just installs  v 17.25.2.1 .
Have you got a direct link I can use please? thanks
Message 8 of 11
devangshah
Here's the link.
Devang
Message 9 of 11
Hello.
Educational version downloads v.17.25.2.1and produces same issue.
Regards.
Message 10 of 11
devangshah
Hello Javier,
Thanks for the feedback. We are aware of this. Please download the latest from the ReMake website at:
The installers on EDU site and management accounts are in the process of being upgraded.
Devang
Message 11 of 11
ena.ernest
Yes the 172531 version did work.  Thank you.
