I have had this issue repeatedly. Has anyone had better luck at different times of the day? Or different sized projects? I was able to get one working this morning, but have had no luck with two other ones today.
I just downloaded memento beta. I took some pictures to try it out. However, after the validation process, when I click Create Model and give a name it says:
"Failed to Create Folder "Name of Folder I gave". Please select another name.
The names of the folders I gave were pretty simple .. 1, a, A, aa, 1_a. No matter what name I give I get the same error. Any help ?
Some minor issues:
Arne
Memento Crash online from v1.2.0.7 and the latest v1.3.0.1 just after the app launched and clicking anywhere on the screen. Therefore, Memento offline is ok and works fine.
Do you have an idea ?
There could be an installer related issue. Please try the following and let me know if it solves the problem:
Murali
Hello Murali,
I follow all your instructions ( to be sure, i also delete AAM ) but the issue is the same , Memento crash online but offline ok. The only way to solve this problem for me ( not the best way ) is to install Memento on another PC, just to be online and do upload / download.
i saw another post on the same subject of crash with memento !
Tell me,
Frédéric
Hi Frédéric,
Would you be interested in generating a crash dump for us for further analysis?
Thanks!!!
-Eugene
Hello Eugene,
It's done. I upload and email you memento.dmp ( no memento.qt.dmp available ).
Frédéric
Hi Frédéric,
Thank you for your reply. I have received the files.
Just to confirm, does the crash still occur when you start Memento, or when you start uploading photos?
If convenient, could you also email me the application log file (memento.log), which can be found at the same location ("%localappdata%\Autodesk\Autodesk Memento").
-Eugene
Hello Eugene,
I just sent you memento.log by email.
When i am online, Memento crash when i start it : the screen freeze and no response at all. When offline, all is ok, i can edit my model but no upload / download off course.
When i install the last version on another PC for the firt time ( no previous version on it ), all is ok
Hope this will help you !
Frédéric
Hello!
Some problem what i found already:
- Sometimes, after loading the pictures and clicking to "Create Model" button I cant write into the name field. I need to restart Memento.
- The name of the project can't contain underline like "something_model", I got every time error.
- When I want to load pictures from A360 drive, some of them loaded as blank white picture.
- At exporting object the preserve material function give an error and stop exporting.
Others seems good now 🙂
This is a known limitation that many have reported - we have prioritised the fix and will be releasing an update in next few days.
Murali
Some issues (on Mac Macbook Pro / OSX 10.11 Beta / version 1093)
- The demo-files take ages to load (and won't show).
- Uploading images when resized / cropped with Photos give an error.
- Unmodified images will upload but no object is been shown after downloading the model.
- There is a huge delay when zooming / moving / selecting.
Features
- It would be nice to confirm dialog / buttons with an 'enter' instead clicking.
- A rotation button after importing photos.
- Ability to re-order photos after importing photos.
- Visual feedback when rollover the items in the select-menus.
General Impression
- Spartan approach (interface feels clumpsy / slow)
- It's too slow to actually 'play' with it.
Hiya
before i comment on the reported issues and sugegstions, just a question: are you using the Windows version on Paralels on Mac?
(many of the issues you are reporting work perfectly and havnt been reported, so i assume its paralels and i woudl recommend you start testing our Mac version)
if i am correct, please send me an email at tatjana.dzambazova@autodesk.com and request a Mac version and i will include you in the early Alpha testers of the Mac version
many thanks for your understanding
tanja
hiya Pat,
thanks for your clarification.
in that case please please as indicated in the initial email i sent, do use my email adress and not this forum for Mac realted issues. we dont want to confuse the forum with the builds that are not yet publically available and ready, which your feedback clearly indicates.
Btw,when you say its too slow - do you mean the photo-to-3D reconstruction or while editing the model?
The photo-to-3D reconstruction happens on the cloud and the length does indeed vary depending on many factors (number of photos, network, server queues..), but if you are talking editing in Memento, that is definitely not consistent with what we know we have and what other testers experience, so while yes , we have a LOT to improve and finish in the Mac build, i wonder if something else is the trouble and would love to see if we can figure it out.
i wonder if you have the minimal system requirements indicated on the download page:
Many thanks for your understanding, i would have said maybe you should wait for better releases but as this is not what others experience i would really love to help find out the issue
many thansk
tanja
Hey Tanja,
as I see the system requirements - some bell starts to ring 😉 I'm still on a i5 processor and half the RAM
A pity would loved to test it but this makes it a little odd, could contribute to the GUI but need a prober UIX for that.
Cheerz,
Pat
Export to RCP appears to be broken. Provides very small RCS files (122kB) with virtually no points. Please fix this ASAP. I will have to find someone in the organization with an old version (hopefully it won't make them upgrade) to do this for me now.
Also have to subdivide mesh 2-3x normally to get higher resolution point cloud. Would like an option to set point cloud resolution on export.
