Unable to get scan coordinate system
amuravievQ565R
Message 1 of 8
amuravievQ565R
There is a problem with reading coordinate system information from RCP, RCS using SDK. An empty string is always returned, although ReCap itself displays the coordinate system.
I am talking about these two methods:
/// \brief Get the original coordinate system that is embedded in the RCS file
Autodesk::RealityComputing::Foundation::RCString Autodesk::RealityComputing::Data::RCScan::getOriginalCoordinateSystem() const
/// \brief Get the coordinate system of the project.
///        Scans in one project have the same target coordinate system as the project target coordinate system.
/// \param coordinateSystem The coordinate system of the project
/// \return True if getting coordinate system correctly. False otherwise.
bool Autodesk::RealityComputing::Data::RCProject::getCoordinateSystem(Autodesk::RealityComputing::Foundation::RCString &  coordinateSystem)
Best regards,
Aleksei Muravev
Replies (7)
Message 2 of 8
zhaoyang_ma
Hi @amuravievQ565R,
As Autodesk::RealityComputing::Data::RCProject::getCoordinateSystem returns bool value, what is the returned value when this API is called?
For "although ReCap itself displays the coordinate system", do you mean the coordinate system displayed in the Preferences dialog?
Message 3 of 8
zhaoyang_ma
Hi @amuravievQ565R,
I have given a try to the two APIs and they are working as expected.
Message 4 of 8
amuravievQ565R
Let me give you my example - https://drive.google.com/file/d/1JhAuCUa0LSKeiCNe1USD67kareGV_HbD/view?usp=drive_link
This project was obtained by importing a LAS file, which contained coordinate system information, into ReCap.
Next to RCP and RCP files you can find files with the json extension which contain information about the contents of the files that was obtained using ReCapSDK_v24.0.2. The information about the coordinate system is empty there.
I would appreciate it if you could test the API on this project.
Maybe in the latest version of SDK everything works as it should. I'll try to check it.
Message 5 of 8
zhaoyang_ma
Hi @amuravievQ565R,
I do not have access to the link you mentioned.
But I have tried ReCap SDK 24.0.2 for the second API with our own test data. It works successfully.
To help us diagnose, can you help answer the following questions?
  • Does the issue only occur for a specific ReCap project?
  • When the issue occurs, does the above API return false?
  • Which version of ReCap Pro are you using to create the ReCap project?
Message 6 of 8
amuravievQ565R
Hi @zhaoyang_ma,
Please try again, I have changed the access.
https://drive.google.com/file/d/1JhAuCUa0LSKeiCNe1USD67kareGV_HbD/view?usp=sharing
If there is a problem with downloading the project again, I could upload it to a place where it will be convenient for you to download it from. The archive size is about 160 MB.
I only had this project with a coordinate system.
Yes, the methods return false.
25.0.0.204
Anyway, if everything works for you, then the problem is either in this particular project or in my code. Could you give me a test project where everything works for you, so I can check my code?
Message 7 of 8
zhaoyang_ma
Hi @amuravievQ565R,
I tried and the coordinate system can be read out successfully.
Message 8 of 8
amuravievQ565R
Thanks! So I'm reading this information incorrectly somehow. I'll try to figure it out.
