Importing XYZ file and creating RCP file
mertyWFD7H
mertyWFD7H
Hi. I am a total beginner in both C++ and ReCap SDK.
I want to create the most basic program that imports an XYZ file and creates an RCP file.
I thought that I could use the "Creating from Raw Scans" example in the documentation.
void importCallback(const RCIOStatus& status)
    wprintf(L"Total Progress: %d%%\n", status.getTotalProgress());
void completionCallback(RCCode errCode, const RCBuffer<RCScanImportStatus>&)
    // do something
int main()
    std::cout << "Starting...:\n";
    RCImportFilesSettings importSettings;
    const RCString outputRcpFilePath = L"C:\\Test\\";
    RCProjectImporter importer(outputRcpFilePath);
    RCBuffer<RCString> inputFiles;
    inputFiles.append(L"C:\\Test\\cloud.xyz");
    importer.importFiles(inputFiles, importSettings, importCallback, completionCallback);
    importer.waitTillFinished();
    string str;
    cin >> str;
With this code, I wasn't able to generate anything other than the empty support folder.
Any help would be appreciated. 🙂
yan.fu
Hello @mertyWFD7H ,
Thank you for your interest in using ReCap SDK.
* ReCap SDK doesn't provide xyz file format CCK by default. So you need to implement a .xyz file CCK to support .xyz file import.
class  ASCIIParser : public IRCImportPluginFileParser
public:
ASCIIParser() = default;
virtual ~ASCIIParser() = default;
size_t getScanCount() const override;
//\brief: Get the descriptive metadata for the specified scan index.
DescriptiveScanMetadata getDescriptiveScanMetadata(const size_t index) const override;
//\brief: Get the statistical metadata for the specified scan index.
StatisticalScanMetadata getStatisticalScanMetadata(const size_t index) const override;
//\brief: Begin reading the scan at the specified index.
bool beginScan(const size_t index) override;
// Read the next point, returns true if succeed, returns false if it reaches the end of file
bool readNextPoint(PointNode& pointNode) override;
// Returns true if file opening is succeeded
bool openFile(const RCString& fileName) override;
// Returns whether the current subfile file is closed successfully
bool closeFile() override;
// Return the estimated points number. Returns 0 if don't need progress support.
long long getNumberOfPointsEstimate() override;
Alternatively, you can use RCProjectImportSession. With this class, you need to parse .xyz file and then add the points with RCProjectImportSession::addPointsToScan(). Sample code can be found from the document in ReCap SDK.
Best Regards,
Yan
mertyWFD7H
Hi @yan.fu
Thank you very much for your explanation and code example. These will help me a lot. 🙂
martin.graner
@mertyWFD7H
I'd like to point out an alternative:
Use the RCP Generater sample, and import the data into the memory yourself:
Import the data:
https://www.cplusplus.com/doc/tutorial/files/
And then split the strings by finding the whitespace or tab and depending on the amount of columns you can set the data (3 columns -> XYZ; 4 columns XYZ + intensity; 6 columns XYZ + color; 7 columns XYZ + intensity + color).
Then you can hand it over to the written functions.
mertyWFD7H
Hi @martin.graner
Thank you very much for your help. I will try your method as well.
