Using two image sets to get 3D model,one set is normal ,one set with projection
Hi:
    Is that possible that recap 360 use two image sets to get a 3D model ? like Agisoft photoscan does.
one image set with projection is used to render the 3D mesh,another one set is used to generate the texture.it's real help when we want to scan something or someone in black white one-colored or something that shines.At first we turn on the projection and get extra "noise" on a subject,then it's easy to scan things that have little or no texture, like black leather to get the 3D mesh .then we turn off the projection and finish the normal scanning.
1 Comment
Maybe just need to add one more function that could allow you to re-texture the 3D model with new  images
