Select files from A360
I suggest to be able to
load files on A360, in the project space, instead of from A360 Drive.
At the moment one can only access files on A360 drive, which is really bothersome as eg most of ky work is on A360 and the Forge API does also only work with A360. Should be simple to enable this when selecting files. Thank you
2 Comments
Good idea @Anonymous. This would help me as well - at the moment I find the process disjointed. Would be much better to just select files from A360 in Recap 360.
vidanom
Status changed to: Accepted
