cancelar
Mostrando los resultados de
Quiere decir:
Scan Registration Improvements
When registering a large amount of scans (for exemplar a storey of a building) ReCap should adjust all the scans in the end. (a fine registration after the first registration)
The Idea is from a costumer, translated from German.
At the moment, when you scan a large amount of rooms in a storey, the registration of the scans is not quite good. The scans all "drift" to one direction. So walls that should be straight are curved.
The costumer normally scans in a circular pattern, so the first and the last scan in a storey are nearly the same.
So there would be the possibility to do a fine registration of the scans by telling the software something like "scans 57 and 1 are nearly the same - please do an adjustment of all scans". Whit this you could use some geometrical conditions to have a more accurate registration.
Thank you.
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
Enviar idea
