I am logging this on behalf of a user. Request was translated from Spanish:
The user would log a feature improvement request for three (3) suggestions they had for ReCap:
1.- Recap projects based in the outdoors has many problems when trying to register point clouds, especially when the point-cloud scans are separated from each other (or even often if they are close to each other).
a) We would like to see improvements to the registration process - to improve manual registration with targets and geo-referencing.
b) After this adjustment, Recap should have an option to force the registration between the point clouds.
2.- Recap has many problems identifying common elements between cloud and cloud.
a) On many occasions Recap does not identify elements in common either indoors or outdoors, the algorithm it uses should be refined.
b) After this adjustment, Recap should have an option to force the registration between the point clouds. (the same one that I mentioned in point 1)
3.- The recognition of targets is limited.
a) In a survey with a laser scanner you can use targets, squares, circular, spherical, triangular, cubes, or just a sheet of paper, many of these Recap does not identify as targets.
Thank you,
-Scott
