Measure Pipe Diameter
I would like the ability to measure pipe diameters without having to select a second measurement point. I would also like the ability to query pipe diameters in tools like AutoCAD and AutoCAD Plant 3D. Currently, I can snap to the centerline of a pipe and I see the pipe segment being highlighted, but if I want to "back model" the pipe I have to first measure the pipe diameter in ReCap and then model in AutoCAD Plant 3D.
2 Comments
richiee
Added in 2.1.
dtiemeyer
Could someone elaborate on the 'Implemented'. When I go to the documentation, I do not see a way to do what the OP asked, which is provide a single pipe diameter.
https://help.autodesk.com/view/RECAP/ENU/?guid=measure_annotate_markup
