getting level scans from BLK360 to ReCap
ReCap does not seam to read the leveling information coming from the scanner (BLK360), this can be resolved in 3 ways
1. Best option - ReCap should be able to consume and use this leveling data from the scanner
2. ReCap app - create a leveling reference point with the scanner before scanning, use targets to mark level and then manually align in ReCap Pro. Need to add number input for point cloud rotation, not just picking a surface, this is useless for slopped floor!
3. Worst option - Do nothing to address this issue.
2 Comments
Henning_Jesse
This is definitely a required basic function
gsismanACAD
Great ideas, since they have the red laser disto they could integrate it with the IMU. The IMU however is only good to +-3' .....maybe, doesn't specifically say on the spec sheet. You really need targets in the scan located with a dual axis compensated piece of equipment (see survey-grade) to get truly level. Or accurately acquire these AFTER the scan by looking in the scan clouds for defineable usable points to capture.
