Show only
Search instead for
Did you use this format successfully in 2016? We removed it because we learned about several other softwares which use this file extension with a completely different format internally (basically they didn't work at all).
Usually - files with ASC extension are really just text files with the data in a column-based format (similar to PTS). Is this what you have? If so, you should be able to change the extension to TXT and set the column format in the Text Options.
Yes, I have received ASC in various different formats too. In the first instance, I think Recap should still allow it as an import format, but perhaps provide different 'profiles' based on the file content, or these profiles could be embedded into the Open dialog as
