Allow for Control Points to be added after indexing
Prior to exporting a pointcloud, it sometimes makes it easier if you can create a known control point from a paper target or point but it doesn't seem like you can add new coordinates after registering and indexing.
5 Comments
ryan.frenz
This is available now.  From 3D or RealView, select Registration from the main menu.  That will take you back to the 'final' (one pane) registration screen.  From there you can add control points as desired.
-Ryan
jburke
Thanks Ryan!  User error.  I thought that was only to view the scan results.  Thanks again!
ryan.frenz
This is great!  Can you let me know how this process is done?  Can you pick arbitrary non-target points?
ryan.frenz
This document is old but still valid (other than color scheme):
https://knowledge.autodesk.com/support/recap/learn-explore/caas/CloudHelp/cloudhelp/ENU/Reality-Capt...
Yes, you can add control to sphere/checkerboard targets or just single points.
