Using Decap to batch unitfy e57 to rcp
SONA-ARCHITECTURE
SONA-ARCHITECTURE
Hi
I use this commande line :
"D:\PROGRAM FILES\Autodesk\Autodesk ReCap\decap.exe" --importWithLicense "D:\TEMPORAIRE\TMP\OUTPUT" Lu --controlFile "D:\TEMPORAIRE\TMP\INPUT\List.txt" --minRangeClipping 0 --maxRangeClipping 300 --decimation 20 --unify
My List.txt contains those lines :
D:\TEMPORAIRE\TMP\INPUT\lu_Scan_000.e57
D:\TEMPORAIRE\TMP\INPUT\lu_Scan_001.e57
D:\TEMPORAIRE\TMP\INPUT\lu_Scan_002.e57
My directory called D:\TEMPORAIRE\TMP\INPUT\ contains all e57 files
In D:\PROGRAM FILES\Autodesk\Autodesk ReCap\, I've got a plugin directory containings .rcip codecs files like those :
The result is .... nothing happens!!! What's wrong????
Thx for answering me.
Welcome to DeCap.exe.
You have provided the following parameters:
        --importWithLicense
        Lu
        --controlFile
        --minRangeClipping
        0
        --maxRangeClipping
        300
        --decimation
        20
        --unify
Initializing Licensing.  Please wait...
Reading control file "D:\TEMPORAIRE\TMP\INPUT\List.txt"
Setting the min clipping range to 0
Setting the max clipping range to 300
Setting decimation to 20 mm
Enabling unified output
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
SONA-ARCHITECTURE
After multiple tests, I've founded the solution!!!! I'm glad to expose it here :
If you want to make a .rcp from list of .e57 (or other format), follow this method :
  1. Download the Recap 2017 version from sign-in Autodesk
    In fact, this this the Recap 360 2016 version
    Why ? Because I tested with Recap PRO 2020, 2019, 2018, and this solution never works!
  2. Create a directory and stuffs like that
    A directory containing all .e57 and a txt file containing the list of all e57 to group and index in the recap file
  3. on a cmd command and run this command line
"D:\PROGRAM FILES\Autodesk\Autodesk ReCap 360\decap.exe" --importWithLicense "d:\decap\output" scans  --minRangeClipping 0 --maxRangeClipping 200 --decimation 200 --controlFile "d:\decap\list.txt"​
Decap will run ....
  • After that, the result is the creation of the scans.rcp file with all e57 files indexed
Decap will run ....
Be carefull!!!!
Here are the conditions to run this process :
  1. You must be connected and signed with Recap
  2. You will find command line informations about decap.exe here
  3. Have fun
Pierre NAVARRA
SONA-Architecture.
