ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Unable to activate Recap Photo
20 REPLIES 20
Message 1 of 21
autodesk55NZD
2768 Views, 20 Replies
Hi, I downloaded the education edition of Recap Pro that includes Recap Photo.  Recap loads and functions using the activation code but Recap Photo only functions in free 30 day trial mode with no where to enter the activation code.  When I login to the program using my account it takes me to the page to purchase the software.   My account shows the subscription is current.  Not sure how to activate the program.
thanks for your help
20 REPLIES 20
Message 2 of 21
jeffrey.sin
in reply to: autodesk55NZD
HI @autodesk55NZD,
Welcome to the Community.
At this time, ReCap Photo is not yet available for student or education licenses. Although it is already currently in the works and based on the information from our Education Team, it may already be made available by October 31, 2017. You can refer to this Forum post for more information: Student license
I hope this information helps. Let us know if you have any other questions on this.
Jeffrey Sin
Autodesk Customer Support
Message 3 of 21
devangshah
At this moment, ReCap Photo does not provide free online processing for EDU users. We are contemplating a suitable solution for EDU users.
If you are an existing ReMake EDU user then for the time being you may download and continue using ReMake version 17.25.4.3 until November 30th.
Devang
Message 4 of 21
Thanks for you response. I am unable to download Remake from my account control panel. It says the software is no longer available and takes me to Recap. Do you have a link for Remake? Thanks
Eric
Message 5 of 21
Message 6 of 21
devangshah
If you have a valid license , you may download and install the following SFX and its update to get ReMake running:
http://up.autodesk.com/2018/MMNTO/ReMake_172531_Win64_dlm.sfx.exe
http://up.autodesk.com/2018/MMNTO/ReMake_2017_Update_17.25.3.1_to_17.25.4.3.msp
Devang
Message 7 of 21
anil_mistry
in reply to: devangshah
Hi @autodesk55NZD,
I'm just checking in to see if you need more help with this. Did the suggestion that @devangshah provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 8 of 21
autodesk55NZD
in reply to: anil_mistry
Hi, thank you for checking.  I downloaded Remake but the installer would not give me the option to install it since I have ReCap already installed on this computer so my option is to uninstall ReCap then install Remake.  Looks like it should work.
thanks
Message 9 of 21
devangshah
One can either have ReMake or ReCap Photo installed on the machine at one time.
Uninstalling ReCap Photo and then installing ReMake would work.
Devang
Message 10 of 21
anil_mistry
Hi @autodesk55NZD,
Anil Mistry
Message 11 of 21
hi,
i have subscribed an "architecture engineering & construction collection" that includes Recap Pro.
When i use recap photo it asks me to activate recap pro, but i already did it..
So recap photo runs in educational mode.
What to do to understand, i don't find any good answer in the forum.
Thank you.
Message 12 of 21
A collection includes ReCap and not ReCap Pro. ReCap Pro has its own subscription and serial number.
Are you using an education subscription of ReCap ?
Please send your contract id to devang.shah@autodesk.com so taht we know what the exact issue is ?
Devang
Message 13 of 21
Is not Recap photo under student license yet ?
Message 14 of 21
devangshah
If one has an EDU license for 'ReCap Pro', then one gets access to ReCap Photo as an EDU user.
Devang
Message 15 of 21
I have a EDU license. (I filled in all the necessary info, got a licence student key online)
After I installed the software it says "Activate Trial"  the other option is to buy the software 😕
I only want to test the software in a school project , maybe I can use the trial ? (is the trial limited for a 3D project?)
I have a building I captured in photo, and want to create this in 3D to print it out in a 3D printer project.
Thank you
Message 16 of 21
devangshah
If your account id is the same as what you have used to download ReCap Pro from the EDU site, then allow some time (a couple of hours) for the entitlements to take effect. If you have received the serial key for ReCap Pro EDU license, then you should be able to sign-in and use ReCap Photo to create a project soon.
Do let us know if that does not turn out to be the case.
Devang
Message 17 of 21
I logged in with the same e-mail.
I installed it 1 day ago, and the ICON is locked, only option I got is to Start a Trial or buy.
Message 18 of 21
Same problem for me... I downloaded edu version of Recap Pro and got serial number and activated pro, but photo is still locked.
Message 19 of 21
devangshah
Hello filip.olsen & rdotsonQRQBA,
Could you both please send us your serial key, userid, email id registered with Autodesk and contact number at photo.support@autodesk.com if the issue is not yet resolved?
Devang
Message 20 of 21
I guess I have two accounts. I downloaded recap pro with my .edu account rdotson@nvcc.edu, but I also have an account rdotson159.
Here is license info.
Product:
ReCap Pro 2019
License Type:
Education Multi-seat Stand-alone
Access Type:
Single-user
Authorized Usage:
Installation on up to 1250 devices. No network server required*
Product Key:
919K1
Serial Number:
xxx-xxxxxxxx
Term:
3-year term
Licensee:
Northern Virginia Community College
Rail Community
