- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I want to know if it is possible to truncate the survey coordinates in Recap 360 Pro.
We typically receive laser scan projects in RCP format (internally or externally) in the correct state plane coordinate system. In order to use this point cloud data in the design interface, it is preferred/required to work with smaller coordinate values. One of our preferred solutions is to truncate the survey coordinate system (i.e. 1,234,567.89' to 4,567.89'). This makes the conversion back to full survey coordinates, when necessary, much easier.
Our workflow now is to go back to the originator of the RCP file and have them go back through the registration process to redefine the coordinate system. This usually takes a lot of time and effort, back and forth, to explain exactly what we need. It would be a lot easier if this is something I could do myself in Recap.
