Synchronize / import BLK data without registration
Scanner2GO
Scanner2GO
Hi Recap Team,
we are looking to a workflow to synchronize the blk data with recap mobile without registering the data? Sometimes it is just easier to hand over the scanning positions without registration into ReCap Pro on the desktop because it’s a lot faster to register the scans on a pc using a mouse and a keyboard.
A lot of our rental clients cannot carry the ipad on side because they are just to busy or it just not practical or they having issue with the lifetime of the iPad battery. In these cases, they use the one button option of the blk to capture the data whole day long to the internal hard drive.
If they transfer the data afterwards they must confirm each scan on the ipad during the transfer process. But it makes no sense if your desktop is next to you. So is there a way to skip the registration for all scans at once or can we as ReCap use ask for it?
@Anonymous community. Please vote if you like the idea of direct tansfer the blk data to ReCap Pro. Thanks. Smiley Happy
Eike
anil_mistry
Autodesk Support
Autodesk Support
Hi @Scanner2GO,
Thank you for participating in our Community! At this point ReCap pro mobile application will allow you to skip registration individually and allow you to import to ReCap Desktop application. As far as I know you can't skip the registration for all scans at once. This is an enhancement request and If you have any feedback that you would like to submit regarding any enhancement, please click on the “ReCap IdeaStation” link on the ReCap community home page.  This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Scanner2GO,
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Scanner2GO
Problem is solved. Thanks again.
